1. Product: 10" Driver custom built using a Stryke HE15 motor. Its similar to the earlier sw9100 3hp's except this one is "sandwiched" with 2-1" slugs and a .75" between them. Also the gap is larger then the 3hp. 10" Brand new TI basket with gold plated terminals, dual mirrored linear roll ultra soft 8.75" spiders with sewn in flat leads, one piece titanium audiopulse/tc sounds cone with high roll rubber surround. And i used an alpine type r gasket i had laying around since this didnt have one. Looks **** imo. And the most rare is the D1 Aluminum FW LMS coil. 3.4" ww.
2. Specs: 750-1k rms. coils read 1.2ohms each. powered for break-in, ts parameters, and linearity.
here are tsp's.
*TC custom D1-taken in series*
FS- 27.59hz
QTS- 0.621
QES- 0.751
QMS- 3.574
VAS- 0.6914cuft
RE- 2.434 ohms
LE- 2.312 mH
Zmax- 14.01 ohms
Xmax- 29mm
xmech-29mm (mechanically limited)
MMS- 251g
CMS- 0.13 mm/N
BL- 11.88 tm
SENS- 79.28db 1w/1m
linearity passed, xmax and xmech are the same. 29mm. Its limited by the cone touching the spiders so your guaranteed to never exceed xmax. Lol.
Designed like that to have the utmost distortion free sound. Meant to be used in a HT setup. 2-3cu sealed on 500w would produce an f3 between 28hz and 32hz with -3db roll off to 24hz. Personally i would run 2cu for dynamics so you dont kill it with 16hz explosion "pops".
3. Description/Condition: 100% working. used only for break in tsp testing. 8/10 cosmetic. motor has some tarnish from age and the cone has a few light dimples but very hard to notice. Careless fingers
4. Price: :320 shipped. This is a one time offer. I need money fast for sa8 recones so i lost my mind today and posted this. ABSOLUTELY NO TRADES.
If i get the money i need for recones, this will be closed as fast as it opened. I really DO NOT wanna sell it but i have shows to do.
here are tsp's.
FS- 27.59hz
QTS- 0.621
QES- 0.751
QMS- 3.574
VAS- 0.6914cuft
RE- 2.434 ohms
LE- 2.312 mH
Zmax- 14.01 ohms
Xmax- 29mm
MMS- 251g
CMS- 0.13 mm/N
BL- 11.88 tm
SENS- 79.28db 1w/1m
