SUPER EASY wiring question, please help!! Thanks added!
eb2phkingood
AMP: FXA102 - FX SERIES - Cadence Acoustics, LTD
Sub: Rockford Fosgate® - P2D412
Amp says its 4ohms bridged. So i have 1 wire to the positive Right speaker terminal, and 1 wire to the negative Left speaker terminal to make it bridged. From there i ran it to a dual 4 ohm P2 sub. I attached the positive to the positive of one coil and the negative to the negative of the other coil. from there i put a small wire between the positive and negative terminals for the other coil. This will give a 4ohm load correct?? It is wired correctly? if not, how should it be wired??
thanks added to first few people who help out!!
eb2phkingood
eb2phkingood
kansas
Deeper_shades
AJ (ACE)
    Jun 28, 2026
