Sundown SAZ-3000ds at 1 ohm strapped or .5 ohms each?
i am using 1 each saz 3000 @ .5 ohm on 1 each dd9515G
there is more than enough power in 1 each saz 3000 to push my dd 9515g to it mechanical limits
so you should be okay but be very careful
easy on your gains & volume knob
Hopefully those NSBs will keep up with the demand. 360 lbs of battery better be able to deliver some juice. How would I benefit with the Maxxlink VS. just gain matching with a DMM? I am not real familiar with it.
Jacobcan build you nightshades that can accept 1 each SAZ 3000 on each nightshade
I would not highly suggest using a 3000D @ 1/2 ohm on them daily, although, it has been done successfully .
I generally suggest 1 ohm for daily... but, again, if you err on the side of caution you can do it.
groundpound4200
Da fuq did I just read?
groundpound4200
Mankato, MN
roarzorz
