Sundown Saz-3000 &100.4D 700 + actual shipping
thecartel252
NC
1. Products: Sundown Saz-3000 &100.4D
The SAZ-3000D
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $1549 USD
The SAX-100.4
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
MSRP $549 USD
I want 700 shipped/obo
Amps are Pianted Kandy Tangarine to match my car. Due to the way they were mounted there are some rub marks. The 3k has striped speaker temails but still hold 8ga with no problem. Any thing small won't hold. You can always have them tapped but wasn't a problem for me. The 100.4 is blown but is still under warranty until Feb. Jacob said he will have it fixed under warranty but it will have to go to Db-r because its painted.
sorry for the crappy photos. I can't find my camera. And for anyone that want these can repaint them for you about 75-100 depending on color. I paint car for a living some it wont be some can spay paint crap.
thecartel252
thecartel252
NC
thecartel252
