Sundown SAZ 2500D like new!
Traks
Sundown SAZ 2500D
9/10 few scratches around the feet from mountin
$500 + shipping
SPECIFICATIONS:
•Digital Class-D Linkable Mono Block Amplifier
•Double Sided Through Hole Epoxy PCB
•1 Ohm Stability
•Daisy-Chain Through Output RCA
•Efficiency : 86% @ 4 ohm, at 100Hz
•24dB/Oct Variable Crossover
•Multi-Way Protection Circuitry
•(Thermal/Over Current/Speaker Short/Speaker DC Protection)
•RCA Line Input and Master Output
•24dB Octave Crossover Slope
•24dB Octave Variable Subsonic Crossover Slope
•Variable Bass Boost
•Variable Low Pass Filter
•Variable Phase Shift
•Zero(0) Gauge Power Supply Connectors
•Tested Voltage & THD : 14.4V & Less than 1% THD
•Operating Voltage : DC 10V~18V
•Wired Remote Controller
Rated power output
----RMS power, 2 ohm linkable/dual mono
5000W x 1CH
----RMS power, 1 ohm mono
2500W x 1CH
----RMS power, 2 ohm mono
1200W x 1CH
----RMS power, 4 ohm mono
600W x 1CH
Signal to Noise Ratio
with good electrical, a long time, bc after rise the amp will rarely see .3
Indeed. It was wired at 1 ohm but after rise it was seeing almost 5ohms at 50hz and still clamped alittle over 800 watts out of it.
Traks
Traks
Mattoon,IL
boomzabit
