1. Product: Sundown SAZ-2000d
2. Specs:
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
24dB Octave Variable Subsonic Crossover Slope
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Wired Remote Controller
MSRP $899 USD
2000@1ohm
1000@2ohm
500@4ohm
Rated power output----RMS power, 2 ohm linkable/dual mono
4000W x 1CH----RMS power, 1 ohm mono
2000W x 1CH----RMS power, 2 ohm mono1000W x 1CH----RMS power, 4 ohm mono
500W x 1CHSignal to Noise Ratio>90dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~6dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
3. Description/Condition: The amp is used and has some scratchesbut is not bad. The amp works 100% and comes with bass knob.
4. Price: :400 shipped only trades would be for more power text me anytime 262 914 3145
5. Pictures:
2. Specs:
1 Ohm Stability
Variable Bass Boost
MSRP $899 USD
2000@1ohm
1000@2ohm
500@4ohm
5. Pictures:
