Sold Sundown Nightshade 12" D1
RetroAudioinc
Custom Car Audio Decals
1. Product:
4 Sundown Nightshade 12" D1 custom
2. Specs:
Info from Jacob:
They have 3 prototype spiders (little lower Fs than the current models, these are slightly softer), plus double leads, new aluminum pole plugs, and the newest D1 coil with collar vents.
I asked if it would still be ok on 2000wrms and got this:
While this spider is softer at rest it has a progressively increasing stiffness -- so should be fine.
Specs from site should be close:
  • Dual 2-ohm or Dual 1-ohm Voice Coils Available
  • 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
  • High Temperature Aluminum Voice Coil Former
  • 1500-Watts RMS Power Handling
  • Over 2 inches peak to peak excursion
  • Wide, triple-layer foam surrounds for high excursion
  • Extremely strong paper cones w/ stiffening disc
  • Thick poly dust caps
  • Cast Aluminum 12-spoke basket with cooling vents
  • Triple Stacked 1" x 9" magnet slugs for high motor strength
  • MSRP - $629 USD
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
3. Description/Condition:
Used but like new..
4. Price: :
$300 + shipping EACH, usps parcel post, usps priority or ups you chose..
5. Pictures:
VC 1 reads 1.1
VC 2 reads 1.1
A few of jacobs photos nothing has changed
Well I had 4 for a LONG time then had 2 for about 2 months.. LoL If you want one I got one I know Jacob could build another one or you to match. Got to start some where. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Like I said in your post when you were putting the 18 in the truck 2 12's is much better in there.. I have done 2 12"s in a few standard cabs, I have a crew cab now so just 1 18.. If you want to trade the 18 for the 12 let me know but I could use the $$$ more.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah I have to have doors wide open for it to get loud like I want. Id rather have like 2 12s or some 10s. ill keep it in mind...would like 2 though
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
