1. Product:
1 Sundown Nightshade 12" D1 custom
2. Specs:
Info from Jacob:
They have 3 prototype spiders (little lower Fs than the current models, these are slightly softer), plus double leads, new aluminum pole plugs, and the newest D1 coil with collar vents.
I asked if it would still be ok on 2000wrms and got this:
While this spider is softer at rest it has a progressively increasing stiffness -- so should be fine.
Specs from site should be close:
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
3. Description/Condition:
This one was only used by jacob him self I have not used this one still in the org box from jacob. I am using the other 2 in my truck and just did a show with them and they are both on my memphis 4k and sounded great did a 148.7 with them.
4. Price: :
$375 shipped.
5. Pictures:
A few of jacobs photos nothing has changed
2. Specs:
Info from Jacob:
- Dual 2-ohm or Dual 1-ohm Voice Coils Available
- 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
- High Temperature Aluminum Voice Coil Former
- 1500-Watts RMS Power Handling
- Over 2 inches peak to peak excursion
- Wide, triple-layer foam surrounds for high excursion
- Extremely strong paper cones w/ stiffening disc
- Thick poly dust caps
- Cast Aluminum 12-spoke basket with cooling vents
- Triple Stacked 1" x 9" magnet slugs for high motor strength
- MSRP - $629 USD
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
4. Price: :
$375 shipped.
5. Pictures:
