Sundown : New Amps 2013
sundownz
Pro Seller
Supporting Vendor
11,349
North Carolina
Been doing alot of work on some new amp products -- I don't get the time I used to on the forums to keep everyone in the loop but I'll go ahead and announce them today! Production is starting this week so we are looking at ~90 days or so. I won't be starting pre-orders right away but do expect a pre-order at some point once I get more solid time-lines.
SAX-150.2 ($400 MAP) : Two channel Full-Range Class-D design (similar to 125.4) -- also runs on 19v like SAX-125.4
SAX-100.4 v.2 ($400 MAP) : Four channel Class-A/B design with similar crossovers to the 125.4 -- but a lower price as it's an A/B amp. Now featuring a fan as with most of our new stuff. This model will run to 16.5 volts.
SAZ-5000D ($1520 MAP) : All new case tool about 3" narrower than the 4500D/NS-1 casing; similar design to the 4500D but beefed up to carry a 5000 rating from us.
NS-1 v.2 ($1900 MAP) : Same new case as 5000D; will be about 3" narrower / 3" longer than current model with pretty well identical internal components and same price. Many customers were looking to go narrower so we've been working on this for a bit.
Some of the SAE amps will also be launching -- MAP will be close to what I discussed originally. I posted about the "E" line prototypes some time ago; I was very happy with them. Now a few are coming out this year. Case tool will look similar to the newer case SAZ line. These come with remotes / are stable to 16.0 volts (not 16v system stable). There are some changes compared to prototypes and I will get more information up before any pre-ordering goes up.
SAE-600D ($209 MAP) : The board is like the "500D" I posted about a while back that well exceeded the power expectations.
http://www.caraudioclassifieds.org/forum/sundown-audio/89173-ns-1-sae-500d-prototype-pictures.htmlhttp://www.caraudioclassifieds.org/forum/sundown-audio/89173-ns-1-sae-500d-prototype-pictures.html[/URL]
SAE-1000D ($269 MAP) : Little smaller version of the 1200D board posted about earlier.
http://www.caraudioclassifieds.org/forum/sundown-audio/107782-sae-800d-1200d-50-4-prototypes.html
SAE-50.4 ($159 MAP) : More basic crossover function from our other gear -- Class-A/B design. Pretty much like the prototype but with our tooled case.
[url=[/URL][URL="http://www.caraudioclassifieds.org/forum/sundown-audio/107782-sae-800d-1200d-50-4-prototypes.html"]http://www.caraudioclassifieds.org/forum/sundown-audio/107782-sae-800d-1200d-50-4-prototypes.html]http://www.caraudioclassifieds.org/forum/sundown-audio/107782-sae-800d-1200d-50-4-prototypes.html
I will start releasing more information as we get closer to pre-orders. Info that isn't here already and pictures will be coming along!
Some 150.2 and 100.4 v.2 photos :
* SAZ-1200D above the SAX-150.2
* 150.2 crossovers
* 150.2 internals.
* SAZ-1200D above the SAX-100.4 v.2
* SAX-100.4 v.2 crossovers
* SAX-100.4 v.2 internals
Info on the other amps will be coming along as well ; but not today -- so I didn't forget; just stay tuned //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
macisme
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
