Sundown Audio SAZ-3000d
cman0655555
• 9/10 cosmetic
• 10/10 function
• Used but in great condition. Has a very small nick in the heatsink but isn’t bad at all. Other than that looks brand new.
SAZ-3000D
• Double Sided Through Hole Epoxy PCB
• Efficiency : 86% @ 4 ohm, at 100Hz
• 24dB/Oct Variable Crossover
• Multi-Way Protection Circuitry
• (Thermal/Over Current/Speaker Short/Speaker DC Protection)
• Variable Subsonic Filter
• Variable Bass Boost
• Variable Low Pass Filter
• Variable Phase Shift
• Zero(0) Gauge Power Supply Connectors
• Tested Voltage & THD : 14.4V & Less than 1% THD
• Operating Voltage : DC 10V~18V
• Digital Class-D Linkable Mono Block Amplifier
• 1 Ohm Stability
• RCA Line Input and Master Output
• 24dB Octave Crossover Slope
• Wired Remote Controller
• MSRP $1549 USD
• Rated power output
• RMS power, 2 ohm linkable/dual mono 6000W x 1CH
• RMS power, 1 ohm mono 3000W x 1CH
• RMS power, 2 ohm mono 1600W x 1CH
• RMS power, 4 ohm mono 800W x 1CH
• Signal to Noise Ratio >90dB
• Low pass frequency crossover 35Hz~300Hz
• Subsonic filter 10Hz~60Hz
• Bass boost @ 45Hz 0~18dB
• Phase shift control 0~180 degree
• Frequency response 10Hz~350Hz (+/- 1dB)
• T.H.D @ 4 ohm
• Fuse rating 300A (external type fuse)
• Input Sensitivity 200mV to 6V (+/- 5%)
• Dimensions 252(W) x 53(H) x 594(L)mm
500+actual shipping
Only trades would be for a dual 2 10 or 12'' FI Q, Sundown Z series or similar +cash on your end.
Have original packaging and boxes from sundown which will be used to ship. I will insure as well. If you are local or close to me would be willing to meet halfway or deliver for a reasonable fee.
Pics are older but it has been for sale for a while on local forums with no luck. Nothing has changed its just been sitting around. I can get newer pictures if desired. Also can get pics of the packaging/boxes if desired. Its just sitting around and I thought I was going to be upgrading but in turn will be downgrading to save space. Thanks
whats the best price to 19525?
Pm sent.
---------- Post added at 12:58 PM ---------- Previous post was at 12:58 PM ----------
Please no offers on trading other amps as I have all I need currently. Also have no use for anything that is a bigger than a 12'' sub as I cant fit it. Thanks for the interest though.
Mines has the model number in both corners, and it's full of fins on the side, can they be strapped? Or are they like the aq3500.1 where it gets a little smoky in the car if the newer one mixes with the older ones?
I didnt think they made 2 versions of the 3000d but I may be wrong. To my knowledge they would be strappable. I know you can strap the v1 1500's and v2 1500's and not have any problems. Someone feel free to correct me if I am wrong. Are you sure you dont have a 3500?
Anyone got an answer to this?
My 3000 also has it in both corners, I think ours is the newest release of 3k. Strapping them together should work, idk for sure though
cman0655555
cman0655555
Carlisle, KY
babybrat86
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
