Sundown 1500D Strapped
i g2g to work but FYI i want to do a strapped pair, each amp getting a .7 load, hoping for max watts, electrical will be no problem. may run 16v is possible...
ido i do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
5kw out of a strapped pair @ 12.8 volts and 2 ohm actual ( 1 ohm per amp )
they were strapped @ 1 ohm (.5 per amp )
When you say this...what kind of VC config?
For instance, you have one dual 1 ohm sub, which you wire to .5 ohm. By strapping, each amp "sees" 1 ohm or .5 ohm?
My strapps at 2 ohms. Therefore I need a dual 2 ohm sub? Wire down to 1 ohm, then each amp will see 2 ohms strapped?
Dual 1ohm subwoofer, 2 strapped amps PER coil.
nG
I know a good place that sells them. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Oh and by the way Sundown dealers will be having a sale on the SAZ-1500D and SAX-100.2 to coniside with the pre-sale price of the new SAX 100.4.
I need to get the pair of SAZ's back in my truck... and clamp them. I really do.
nG
I'd be interested to see how it turns out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm not really sure what the impedance was at the frequency we used, you should keep that in mind. The readings were on the FI Audio BTL at a low frequency. Maybe Chad or Loyd can offer insight into the box specifics.
x2
Werid how supposely 5000rms is quieter than 3000rms??? maybe its just me:D
i thought the same thing when jism mentioned that before //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
in the end, i guess the tl means more than the fluke //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
photocrazy8
Probably doesn't like you
photocrazy8
CA
ngsm13
