Sundown 125.2
cal
sundown 125.2
Rated power output
----RMS power, 4 ohm stereo
125W x 2CH
----RMS power, 2 ohm stereo
200W x 2CH
----RMS power, 4 ohm bridged
400W x 1CH
Signal to Noise Ratio
>90dB
Low pass frequency crossover
50Hz ~ 5KHz
High Pass Crossover
30Hz ~ 3KHz
Variable Subsonic Filter
10Hz to 500Hz
Bass Boost
0~18dB
Variable Bass-Boost Frequency Control
35Hz to 120Hz
Frequency Response
10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts
Channel Separation
75dB
Fuse Rating
20A x 3
Input Sensitivity
Variable 200mV~6V (+/- 5%)
Dimensions
252(W) x 58(H) x 340(L)mm
SPECIFICATIONS:
•2/1 Channel Bridgeable Class-AB Amplifier
•MOSFET PWM Power Supply
•Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
•12dB Octave Electronic Crossover Slope
•Variable Subsonic Filter
•High Pass Filter Variable with x 10 Range Selectable Switch
•Low Pass Filter Variable with x 10 Range Selectable Switch
•HPF/FULL/LPF Selectable Switch
•Variable Bass Boost Control
•Variable Bass-Boost Frequency Control
•Variable Input Level Control
•Input Sensitivity : 200mV ~ 6V
•Subsonic Filter : 10Hz ~ 500Hz
•Signal Input and Line Out RCA Connectors
•Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
•Tested Voltage & THD: 14.4V & Less than 0.05% THD
•Operating Voltage : DC10V~16V Power Input
used but fully working . imo amp is clean, im real picky so i took detailed pics so u can judge the condition . amp is active capable and is beast never had issues , i bought 2 of these but cant fit them in my build if somebody needs 2 the other one can be sold as well. no original box but will include a remote gain
165 shipped con u.s.
no trades
cal
cal
cal
