Rawr-DQ
!!!!Vote Third Party!!!!
I decided to move over here because I might as well build something this week.
I calibrated and tested this neo oddball with a WT3 woofer tester; do these specs look alright; does the box have any flaws I should be careful of falling into.
Trying out a 4th order bandpass design
Box Properties
Name:
Type: Bandpass Single-Tuned Box
Shape: rectangle, Bandpass
with two chambers
Chamber 1 - lower-freq.
Vb = 6.368 cu.ft
Fb = 39.39 Hz
QL = 5.207
F3 = 27.99 Hz
Fill = heavy
Chamber 2 - upper-freq.
Vb = 2.176 cu.ft
Fb = 45.89 Hz
QL = 6.239
F3 = 70.23 Hz
Fill = none
No. of Vents = 2
Vent shape = round
Vent ends = no flush
Dv = 6 in
Lv = 30 in
The box, the second smaller chamber will house about 14" of the port, they're 6" diameter and 30" long
I did more testing; here are the SS wt3 program:
Test Lead Calibration
Test lead calibration with 1k ohm resistor
Series Free Air
Series Vas Cal
missing
Parallel Free Air
Parallel Vas Cal
missing
Box Properties
Name:
with two chambers
Vb = 6.368 cu.ft
Fb = 39.39 Hz
QL = 5.207
F3 = 27.99 Hz
Fill = heavy
Vb = 2.176 cu.ft
Fb = 45.89 Hz
QL = 6.239
F3 = 70.23 Hz
Fill = none
No. of Vents = 2
Vent shape = round
Dv = 6 in
Lv = 30 in
Series Free Air
Series Vas Cal
missing
Parallel Free Air
Parallel Vas Cal
missing
