Suggestions?
What are some of the best subs for the lows but can still play music? Most set ups around here are alright for lows and kill the highs but I want something that will absolutly kill the lows
the xcon just kills lows
the shiva-x2 is a low end monster and so is the tc sounds, they are by no means spl subs at all. truly low end monsters. plus low end all depends on the build of the box, the box is everything.
IXL-15.2.2 [iXL-15.2.2] - $199.00 : Mach 5 Audio
also a low end monster if you look at the fs its extremely low in lower 20's, not as low as the shiva but really low, but will be louder then the shiva
I was actually thinking about the SA-8's just because no one around here has 8s and everyone thinks bigger is better and I kinda want the shock and awe but will they get low? Also I should be looking at the fs to see if the sub will kill the lows?
Im running 2 SA-8s on an AQ2200d, they romp on the lows, come spring there will be 3 or 4 in my trunk.
yes the lower the fs, the lower the sub likea to play
SSA Shop - Sundown Audio Nightshade 15" Sub woofer
this is more of a spl sub hence the fs of 40
also xmax is another, the longer the throw the lower it will go.
Thanks!! I'll start looking into the suggested subs and start working on a decision, I will more than likely have some more questions tho. What do you guys think would be cooler? I know its whatever I want but I also want it to be awesome! So
1 18
6 8's
2 12's
DylanH
DylanH
Iowa
mechavore884
