Suggestions on how to seal this?
Having two SA-12s in an Access Cab puts it incredibly close to the rear/door windows. My port is just inches from my rear door window. The handle is already broke, so I had to tape the handle down to keep it from flying out. But because it is already broken, it rattles like no other, especially noticeable on the outside of the vehicle. Any suggestions on how I could seal it off so it won't rattle as much?
Drill a small hole through the window latch and panel, insert bolt trough the back, install panel, pull bolt through latch and top it off with a nut.
Don't know if that's possible as all I see is red tape but it's all I could think of.
it would be easier if you can pull the roll-pin from the lever, but you may need to bend the metal mounting in to tighten it... and look for areas you can tighten it up with foam tape or something to take up any play.
fatboytyler
fatboytyler
Easternl Kentucky
mylows10
