Suggestions on 12;s ideal @ 1.1 cu/ft
Are you willing to give up output in the process? If you keep box volume the same, and want to improve low-end extension, then you will have to give up a little efficiency in the process -- no way around it. The only way to keep output the same is to increase power at the same time.
One option: http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=293-610
Probably more than you wanted to spend, though.
97srad750
97srad750
Lexington, SC
TeoTorriatte
