suggestions 4 88 civic
Hmm, maybe tune lower ( CRXs usually are tuned higher... as of my knowledge - might be wrong )
... More port area ( bigger port.... different style port )
Instead of L shape, slot, square... use a 6" - 8" circle .....
... just don't limit yourself, or get disappointed cause it didnt do what it did before.
Just cause it hit a 151 in that car, don't mean it'll be the same in another. ( The bug could have peaked @ at 49 ... this car might peak @ 54...
ya i know i have 5 4" psp ports now but think i'll go with a slot port tuned to around 37hz sub and port up box will be 33x37.5x16.75 outside dimentions will start building this afternoon unless someone knows that haveing the subs forward gives a better reading on the mic. Thanks for the help everyone
Well... make it like this!
* My story *
I had the Superbass ported probox for 12s facing the trunk - 139.6 ( Nissan Sentra )
I turned the box around, facing the cabin - 140.7 ( Nissan Sentra )
Bought the Superbass ported probox for L7s ( Modded it for circles - facing the trunk ) - 142.3
I turned the box around, facing the cabin - 144.2
* both were tuned @ ~50hz ... Same style box, just different size *
... Well, I finally built a box - Instead of the port right down the middle, port is on the side, subs facing the trunk. Tuned @ ~48.39 - 146.5
Point - You just gotta play around.
.... I put this setup in my honda ( 146.9 ). and then in my 4 runner ( 145.8 ) * And I thought it was gonna be louder in the SUV... sike
this is what mcbuggin has right now..............
first question...
8 cu ft net, supposed to have 128 sq inches of port area...
have a 136 inches of port area, is that too mutch
3 8'' areo ports
looking to tune it to 37 hz...
sub's forward, port's back.
in a 88 honda civic hatchback
two 15'' AQ hdc3's
wanting more allong the spl.
secound question...
allso in a 88 civic hatchback, goal here is pure spl.
what do you think the box design should be?
port's forward, out the rear? up?
sub's up, back, forward??
IMO - Question 1: More port area....
IMO - Question 2: You won't know until you do each one with each one....
* subs forward - port up/forward/back/side
* subs up - port up/forward/back/side
* subs back - port up/forward/back side
** I've seen this ** subs side - port foward/back
Draw each one up...
... See which one you like the most
Post pictures, ask for comments on design
... Take whatever comments or advice ( only yours really counts )
Then apply
mcbuggin
mcbuggin
smithfield,UT.
NissanKicker
slater
    Oct 4, 2025
    Oct 4, 2025
