sufficient wattage?
A boss 5500 will do less than the ppi bk1800. The subs will not handle 1500 watts. And unless you have electrical upgrades thats about as far as you want to go. The ppi has more than enough power to destroy those subs. Not trying to be el douchey, but I don't want you wasting your money either
I've never heard of that brand but it doesn't sound very big? I'll check it out though... class d?
that boss 5500 amp only does 500 actual watts on its best day. Anything from garbage companies like boss, pyle, pyramid, power acoustic, planet audio, autotek, crunch, you take out a 0 at the end and you get its true numbers.
Most fail within a week to a month of usuage if they havent already come dead on arrival.
That ppi bk 1800 will be too much for your boss subs since that one actually does real power. You can definitely run it with your subs and they will get pushed to the max, just be careful with the amp's gain settings and you should be fine, but you'll definitely want to upgrade the subs later on to REAL subs.
If it sounds too good to be true, its ripoff. Garbage companies lie about numbers all the time trick noobs into buying garbage.
all he has to do it set the gain right. he will have good head room.
What 15" would y'all recommend without it costing me an arm and leg then? the last boss amp i had did great for over a year then my system was stolen. i want good bass and sound quality and it'll be in a van
trav
trav
bacon, mo
big scott
