DMarsh525
i noticed some amps have this subsonic filter and some dont. what it do and do i really need one?
When you say the Q can be controlled, do you mean the total Q as in Qts? If so, how does the amplifier control Qes or Qms, because it has to control one of them in order to change the Qts.My Orion has a SSF with variable frequency AND variable Q. That Q adjust is a freaking Godsend. I can make my system peak in the high 20s for competition. A really high number is great, but a moderately high number at 29hz is worthy of mentioning anywhere. =)
I only mention this because everything that can be said has been already, so what can I add?
For every octave below 25hz, the output will be reduced by 12dB. So as soon as the notes start to dip below 25Hz they will be attenuated. I imagine the SSF on that kicker is adjustable, a set SSF @ 25hz is pretty **** low and not at all on the safe side for those who are ported to around 35Hz.I came here tonight to ask this exact same question.
Now, my KX1200.1 has a subsonic filter. The manual lists it as 12dB at 25hz. Does this mean it will filter out any notes below 25hz? Since I'll be using a ported enclosure, do I need to use it on my amp?
no, not quite. Q is best visualized in bandpass or bandstop filters (such as a typical parametric EQ). basically, Setting tuned frequency shows you where in the spectrum the effect is, and Q shows how frequencies near the tuned frequency are affected.When you say the Q can be controlled, do you mean the total Q as in Qts? If so, how does the amplifier control Qes or Qms, because it has to control one of them in order to change the Qts.
