subs+amp???
would this amp
Metrik MAH-1022 Platinum Series 1600W Amplifier
2-channel MOSFET amplifier
1600 watts peak power
800 watts x 2 @ 2 ohms
300 watts x 2 @4 ohms
>90dB S/N ratio
work well with these subs
2 Kicker 12" CompVR CVR124 Dual 2 ohms Subs
im new to the woofer world so any help is much appreciated
-thanks
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Welcome to the forum for both being a new member plus being a fellow Louisianian! //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Metrik isn't a manufacturer that I am familiar with in the least.
Are those power ratings (the 800 X 2 and 300 X 2) RMS or peak, if you know?
If you have it already then, find out if it is stable under 1 ohm....If not then you have to wire your subs in series to get a 4 ohm load for each and only get a "rated" 300 watts to each.......What does the amp put out bridged?
EDIT: Assuming this is budget.....Just get a Hifonics BXi1606D and wire the subwoofers in series for a 2 ohm load and each sub should see around 400RMS
welcome to the forums.. i'm from south louisiana myself. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what is the budget on an amp. if its around 300-400 dollars, http://www.sonicelectronix.com/item_5432_Soundstream+PCA1000D.html or http://www.sonicelectronix.com/item_7444_JBL+GTO1201.1II.html
both are good amps and should do you good. im planning on getting one of those. or unless you can find an amp that is stable at 0.5 ohm and wire it like that. or that hifonics brutus should do you good as well.
trillfam225
trillfam225
South Louisiana
trillfam225
