sub woofer wiring help
cmp69
Ma
i have 2 12 inch audiobahn aw1200Q's and i have them in a dual 12 inch sealed box
how do i wire the subs in the box...in each hole for the sub there are 2 wires a pos. and a neg. my subs have dual 4 ohm voice coils, and im wiring them to a 2ohm amp in parallel....where do i put the wires that are inside the box to the subs..a good answer would be greatly helpful
thanks alot
what brand / model amp do you have and what are its specs... rms watts, ohms, channels. with DVC 4ohm you can only get either a 4ohm or 1ohm load for a mono amp.
i have a jbl bp1200.1 and its stable at 4 and 2 ohms, and i have 2 audiobahn aw1200Q's they have 700 watts rms, and the amp does 600 at 4 ohms and 1200 at 2 ohms
i think someone said that amp is 1 ohm stable - check the manual. if it is you are in luck.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
the JBL manual says that the amp is definitely 1-ohm stable, but output is not any more than the output at 2 ohms. So you'll have a one ohm load with 600 watts going to each sub. I'm guessing the bass from those 1200Q's will interfere with your heartbeat.
Originally posted by Ganji the JBL manual says that the amp is definitely 1-ohm stable, but output is not any more than the output at 2 ohms. So you'll have a one ohm load with 600 watts going to each sub. I'm guessing the bass from those 1200Q's will interfere with your heartbeat.
BONUS!!! wire it all up for a 1 ohm load and pound it loud!!! wire everything in parallel = all + to + and - to -. from the box terminals wire two sets of wires from the + to + and - to - of each VC for each sub. and then wire from the amp to the box terminals all + to + and - to - and you will be ready to rock.
cmp69
cmp69
Ma
imral3
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
