sub wiring?
brown7348
Single sa8 dvc d2, im going to be using a boss cx750 2 channel 2ohm stable amp, I know its a junk amp but its what i have for the moment, Any help on wiring it up to get the most power even though this amp will probably only tickle this sub..
if it isn't stable at 1 ohm it'll have to be wired to 4 ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif which probably really only will tickle that sub haha
The way I see it, you only have one option. The sub is dual 2 meaning you can wire it to 4ohms or 1. Your amp is not 1 ohm stable therefor you must wire to 4. Also I bet the amp is only 4ohm stable bridged anyway.
Lol, yea im going to have to have a good mono amp to punch it, i have been tickling subs for years now but never had one laugh.. So i can wire the sub in series and bridge it to get all i can from it right??
Also worried about having to use full gain and bass boost to get it going, I do not know if this is bad to run it wide open on my new sub even with low wattage.
brown7348
brown7348
east texas
brown7348
