sub wiring?
smokeoff
here's my 3 cents
I am wiring my 12.44 k to 2ohms. With the wire going from one terminal to the next do you cut it and have one wire connecting both terminals or do you strip the wire so one single wire connects to both. If you under stand what I am asking respond.
Originally posted by smokeoff I am wiring my 12.44 k to 2ohms. With the wire going from one terminal to the next do you cut it and have one wire connecting both terminals or do you strip the wire so one single wire connects to both. If you under stand what I am asking respond.
well it would be tough to use a single wire unless u actually thread the entire wire throught the push pin terminal and strip the part off the goes exactly on it. So, the answer is...use use 2 wires. One short wire from pos. to pos. the another wire from the pos. to the terminal. Same for the negative. peace
NG
thanks. the sub has some decent sized terminals though. All I would have to do is cut the jacket off of the wire and slip it through. Would that make for a more secure connection or not.
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
smokeoff
