sub wiring quick question
Thedeadly1
I just wired my subs in a parallel, two svc 4 ohms to one 2 ohm load. I used the entire wire to go from point to point, so theres the brass color and silver color, and i used both of them from point to point, i didn't split them. Is that okay or did i do it wrong?
They are the same wires just have different coatings on them. Doesnt matter which is positive or negative. Did you say you hooked it up in the house? If I recall, HT setups usually run at 8-16ohms, safely.
Thedeadly1
Thedeadly1
miami
Thedeadly1
