sub wiring, 2ohm 15" kicker L7
Kolesters
I don't know what would be the best way to wire my sub
parrele, series or what lol -
Running the Kicker KX1200.1 Mono Class D
d2ohm 15" l7 kicker in a ported box.
how should I wire it? (and what exactly do I have to do to wire it that way)
Thanks!
just like this
parallel. just like he said. + to + ....- to - then to amp...makes the amp see a 1 ohm load, which is what your amp is designed for. it does its rated 1200wrms @ 1 ohm. if you run it series, then you will be underpowering your sub by about 700 watts. cuz that amp only does 300wrms @ 4 ohms.
I thought you said you were getting two 12" solo-x's off 2 zx2500.1's?
Are you gonna have two setups? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Yes, I have more then one car lol - I might re-order something else maybe I should of done some research before I bursted into this lol
the 15" kicker is in my firebird lol - sounds pretty nice tbh just re-wired it to like they siad it it WANGS, car flex's like never before, it seems to hit so low I havent even see how low it hits - i need to find me some good songs //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Kolesters
Kolesters
Indiana
blackbonnie
