sub w/ no amp
  • 2
To run a sub w/out and amp, I usually take out one of the stock speakers and hook up to stock speaker wire to a larger piece of speaker wire and put black tape around where the bigger wire meets the stock wire. It is essential to put tape arround it to prevent a fire. From there, just hook up the wire to the wire terminal on the box and boom, there it is. It always works best if you have an aftermarket h/u with a built in amp. A box and black tape, wire, and wire cutters are all you need!!!
158
745
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
816
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
846
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
more_spl
only have 1, but it's 12"
more_spl
Winnipeg
RangerMan
