zjltwins85 10+ year member
Ok if anyone has advice, it would be appreciated.
I recently had a profile 800sx amp stop working. It was powering 2 12' infinity references in a bandpass box. the amp stopped working, so I hooked up a kicker 300.2 to them to make sure it was the amp. This kicker did the job of powering them, although it wasn't as loud. So I got a box for one sub, and hooked up the kicker to it. Now for some reason there is very little bass coming from the sub. I believe all the wiring is correct, so I don't understand where the problem would be from taking the amp powering 2 12's, to an amp powering one sub and losing almost all output. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
it is an svc 4 ohm sub and so I have the wiring going from the amps l+ and r- to the subs left and right inputs... I messed with the gains, and bass control on the h/u, and the power and ground are all ok...//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
