Stupid question: what would happen if/is this possible?
pwnt by pat
Pat for Prez 2024 - vote!
You take one channel of audio source, and split it out to two amps. Each amp is then bridged and run to a sub. The sub, however, is SVC 4 ohms. The + from each amp goes to the + on the sub, and the - from each amp goes to the - on the sub.
Is it possible to run like this safely and if so, would each amp see a 4 ohm load?
I guess you can try it, but just be careful...Just as long as each amp is 2 ohm stable bridged....as each amp will effectively see only 2 ohms when connected to a four ohm load strapped....the amps are identical right?
Don't think of it as two amps each supplying voltage to a speaker terminal. Think of it as each amp supplying voltage to a speaker terminal AND ANOTHER AMP. Might as well take the speaker out of the system and let the two amps just slug it out with each other; that's one less piece of equipment to let the magic smoke out of.
An amp output is AC current. If you put a diode on it, you get DC and heat, which isn't good for a subwoofer or a diode.
The only possible setup that comes close to what you're thinking of is a DVC sub, with an amp connected to each voice coil. Even that is usually more trouble than it's worth.
pwnt by pat
pwnt by pat
Pa
pwnt by pat
