Selling these for a friend, he had these installed for only about 2 months then his POS car broke down and had to buy a different car. The audio equipment would not fit. They were bought in July/Aug this year, so still under warrenty.
Eclipse CD3403-$150
• Maximum 40W into 4 channels
• MP3/CD-R compatible
• 2 pairs of RCA preamp outputs
• High-voltage (2.7V) & low-impedance output
• 24 station presets (18FM/6AM) & preset scan
• Bass/Treble memory for each source
• Digital Servo System
• NOB rotary volume encoder
2-JL Audio 12w3v2's-$350w/sealed custom box, $250w/o
I think they are D4
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 300 Watts
Voice Coil: 2.25" diameter, 4-layer, Kapton former
Available Configurations: Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
Sealed Enclosure Range: 1.00-1.50 cu.ft. (28.3-42.0 liters)
Ported Enclosure Range: 2.00-3.00 cu.ft. (57.0-85.0 liters)
VRCâ„¢ Technology
Elevated Frame Technology
Zapco Reference 360.4-reasonable offers(no lowballing)?
4-Channel Amp with 2 Way Crossover and Bass Control
Stereo, 4 ohms: 4x50 Watts
Stereo, 2 ohms: 4x90 Watts
Bridged, 4 ohms: 2x180 Watts
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate: >23V/uS
Damping Factor: >160@ 4 ohms
Dimensions: 18"L x 7.5"W x 2"H
SymbiLinkâ„¢ Balanced Inputs
RCA Unbalanced Inputs
2 ohm stereo stable
18 dB variable bass boost control
Dual variable electronic crossover
Dual bridgeable @ 4 ohm
Four channel
High Current Bi-Polar output devices
Optically isolated MOSFET power supply
Switch for use as stereo, single L ch. or R ch. bridge
L+R sum mono for use as a bass amp
Surface mount technology w/1% resistors,
precision caps, and massive ground planes
Like I said these are still reletively new, warrentied and manuals included. If you want pics it may take me a day or 2 to get them.
Eclipse CD3403-$150
I think they are D4
VRCâ„¢ Technology
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate: >23V/uS
2 ohm stereo stable
Four channel
