Strongest bond
slim j
Which of these creates the strongest bond between plastic and mdf
1) ca glue
2) liquid nails
3) two part epoxy
4) fiberglass resin with small holes
5) plastic body panel adhesive (stuff made by evercoat)
depends on what you are doing... are you laying a piece of plastic on the mdf or are you putting it like perpendicular to the mdf?
2 part epoxy works well on plastic, but I have never used it on mdf.
Is it going to be for looks or performance? If you want it to look good, I would NOT use liquid nails
The 3M stuff will probably be as strong as you're going to get. I do know that I used a 2 part epoxy on some PVC ports and there is no way in hell I'm ever going to get them out. I tried my hardest to remove one on a test piece and I almost broke my arm.
slim j
slim j
ca.com
slim j
