strapping D9's ??
outsideshot23
I have a wire jumping from neg on one amp to neg on other amp.. all positive sub wires into the 2 positive terminals on master amp and all neg sub wires to pos on slave amp.. RCA wire from cd player to master.. out of master into input on slave.. then one rca from where the master/slave switch is to other hole on slave amp.. then the other two ends of that rca are lose.. getting power but not like it should.. feels like its only hitting about half... whats wrong?? thanks
You do not want the RCA's from the output of Master going to the input of Slave.
Only thing connecting the Master and Slave is the 2 negatives, and the single RCA at the Master/Slave switch.
Make sure your Master/slave switch is correct for both amps.
and 2 RCA's dangling?
Meaning he is only using one side of the RCA's //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif aka single RCA
outsideshot23
outsideshot23
OKC
outsideshot23
BP1Fanatic
BP1Fanatic
