Strap or Not?
Crownvicon28s
God 1st
Trying to decide between an amp that does around 4k @ 1 ohm ran at .5 ohm or two 3k amps strapped at 2 ohms. I have been told by some that they have actually been more quite when strapping amps. Then I read that rise is spit between amps when strapped so it seems that the strapped amps would make more power. Im thinking I can get a little over 4k with the one amp and maybe 1800 per amp with the strapped amps if they see 2 ohms after rise so 3600. Does this sound correct? Which would you choose, price is very similar with each? They will be powering two Z v.3 15's.
I would personally run a single ddm3b over the Crunch's. Proven clean and reliable power > Unreliable and potentially dirty power any day of the week. The DD would do well over 4k @ .5 ohm provided you can maintain 14V.
As for the strapping logic, I've never strapped, so I couldn't give an honest answer on that.
I only need a clean 4k or so, just figured amps get more inefficient at .5 daily. I will have 320ah of battery and a 240amp alt would that be enough?
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
Mike Mccabe
Giles
    Jun 27, 2026
