Strap AQ2200's or get AQ3500d?
StickyFingaz
Can't decided which would be better strapping two AQ2200's or running a single AQ3500d. I want to power a D1 BTL.
The pros of the 2200's is that I could start with one running at .5ohm then double up later, strapped at 2ohm.
Or I could get the 3500d and run it at 2ohm or at .5ohm to save space and wiring problems.
Also what kind of electrical is going to be required for the above setups?
The new 3500 does 4300 @ 1 so whats your point? You're willing to spend the extra cash to gain 100 watts ?
I am considering the old 3500d. I have heard they will do close to 4400 at 0.5ohm, although for daily I won't be using all that power. Still cheaper than two 2200's....
Will 180ah of batts and a 180amp alt enough to run the 3500d at .5 ohm (keeping an eye on voltage of course)?
Kinda seems like your going to spend either more money on the amps (2 aq2200's @2 ohms) or more on electrical (aq 3500d @.5). I get nervous about running an amp under its rated impedence, although audioque are great amps. If it was me I would strap the 2200's.
The BTL will die on any of that //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
It won't take 3000w of clean power daily? I rather have headroom in case I want 2 bass race or sumthin. Could run @ 2ohms daily, but I was thinking of just going easy on the gain @.5 ohm.
Kinda seems like your going to spend either more money on the amps (2 aq2200's @2 ohms) or more on electrical (aq 3500d @.5). I get nervous about running an amp under its rated impedence' date=' although audioque are great amps. If it was me I would strap the 2200's.[/quote']
I think you would neep similar electrical for both. You have to able to support 4k either setup...
i mailed aq and asked them on running mine at .5 they said alot of people do it with no problem just watch the gain so then i ordered my 4 15" sdcs and now im waiting till next week when i get a delivery of goodies everyday so far! lol subs, alt, batt,s amp!!!! and wire!
The 3500d will take .5ohms daily like a champ and never get warm. Will even burp .25 ohms if your electrical is excellent. I ran 2 AQ 1200's at 1 ohm strapped (.5 ohms each) daily and they never flinched. even burped them a couple times at .5 ohms strapped but they didnt like it too much for daily! Audioque is way more soild then 90% of the crap out there at that price.
StickyFingaz
StickyFingaz
Vernon, BC
resko1
