Stetsom Vulcan 1k5 amazing amp
Jeff Stetsom
Sales Rep Member
The new Vulcan 1k5d is now available !!!
This amplifier is perfect for daily use and for small set up
THE AMPS IS
2.56" H x 11" W x 6.69" L
and it gives you 1500 pure Rms power in 1ohm or 2ohms
Take a look on the flyer on the bottom more info on it
ITS STRAPPABLE
the half brigde system is a way to have the circuit transistors output. The advantage of the Half Bridge is that you can add to power them like batteries in series, if you connect the wire to a speaker and amplifier in one other thread of the same speaker, the other amplifier. In the current amplifiers, you have to connect them in parallel and use the link cable to sync.(like in our linked amps)
more info on
http://www.caraudioclassifieds.org/forum/showthread.php?t=20995
Jeff Stetsom
Sales Rep Member
Jeff Stetsom
boca raton,FL
C3 Customs
