Sold Stetsom 2kd
350zspl
typo my bad amp part # 2k6d
traded with NJAYKAPLAN last night
9-10 cosmetic
i would venture to say that if sound quality from your subs is what you want than this is not for you
but for your subs if you just want spl and gobs of power than it is perfect
$ 400 shipped or best offer
works on 12-14 volts just fine
Wow.. That was pretty quick //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif. I'm installing the jbls as i type this, taking a break because of my empty stomach. The ratings you posted are wrong, It is the 2k6D.. And also, in my multiple page thread, i should have 5 or 6 pictures.. The specs listed above were for the 2kD, which this is not. This is the 2k6D:
Channels: 1
RMS Power @ 13.8V
Mono 4 Ohms: 2200 Watts
Mono 8 Ohms: 1200 Watts
RMS Power @ 12.6V
Mono 4 Ohms: 2150 Watts
Mono 8 Ohms: 1050 Watts
Minimal Input Impedance: 0,2V
Total Harmonic Distortion:
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Input Tension: 9 to 16V
Power Consumption: 3,3 to 240 A
Dimensions : 70 x 280 x 330 mm
Weight: 7,0 Kg.
\/ Buy this mans amp, used for one week just to test out
Channels: 1
RMS Power @ 13.8V
RMS Power @ 12.6V
Weight: 7,0 Kg.
nice thanks for the update on the specs
And i never really compared it to the Sundown 3k, I would assume fairly close powerwise.. Before i had the stetsom, i ran a pair of mtx 81001s which were rated 1500 at 1 ohm, and i ran them incredibly low.. strapped to a half ohm load.. and i gained very slightly switching to the stetsom at a 2 ohm load.. I probably have it saved on my computer, but i'd have to look.
cool Jay
so than this amp you gave me last night can run 1 ohm and not go into protect ??????
Seandub ran his at half ohm daily without any problems on a DD9515E for as long as i had my amplifier, and JUST upgraded to an atomic 5k.. That was very not recommended i'm sure, but i tried it on my bravox (1 ohm load) and the pair of mojos (wired to 2 ohms)
350zspl
350zspl
WPB Florida
poundindak69
