Sold Stetsom 2k6D
njaykaplan
BNIB at the moment.. Will have pictures up later tonight, by camera phone. Odds are, will be slightly used in perfect condition unless i can control myself to keep it wrapped up. 950 new or 850 used, will stay in wrapping and box until after the weekend when i will test it running the single bravox edx.
Specs:
Channels: 1
RMS Power @ 13.8V
Mono 4 Ohms: 2200 Watts
Mono 8 Ohms: 1200 Watts
RMS Power @ 12.6V
Mono 4 Ohms: 2150 Watts
Mono 8 Ohms: 1050 Watts
Minimal Input Impedance: 0,2V
Total Harmonic Distortion:
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Input Tension: 9 to 16V
Power Consumption: 3,3 to 240 A
Dimensions : 70 x 280 x 330 mm
Weight: 7,0 Kg.
trade some crossfire amps ?? 2 vr2000d's anda vr302? i keep wantin to try one of these for some odd reason...... that and im sick of 2 big amps and a lil one takin up room......id run it at 1 ohm tho......
and pics also refs if any.....
are you lookin for any trades or is it a waste of a call....lol....???
just going to work but will check post while i'm working.. i'm open to trades for mostly high-powered amplifiers. will check back around 6:30 at my break. No references here yet, but if your located in florida or georgia, i will be going to atlanta in 2 weeks. Text messages are prefered because i run around and dont always have my phone, but feel free to give me a try.
Bump.. Anyone know what this will do at 1 ohm and half ohm? Tempted to replace my 2 amps with it but i'll be patient.
Word is it'll do 4kw @ 1 ohm and a little more at 0.5 ohm and is stable down to 0.35 ohm daily. However, I have not benched mine so I do not know for sure. On this board you can ask xtremebassjunky or 80inches. They both have experience with these amps also.
What kind of electrical do you have out of curiousity? do you run it .5 ohm daily?
Yes, it is running at 0.5 ohm right now. As far as electrical all I have is 1/0 wiring, 1/0 big three, original battery up front, and a Stinger SP1000 battery in the back. So not much right now because no one makes an alternator over 180 amps for my vehicle and I don't have the cash or space to upgrade my battery bank. But it still runs good.
Btw.. I was looking at your thread.... When you come to the A why dont you stop by the shop and let me take a look at it if you still have it... If its installed still thats fine also...
njaykaplan
njaykaplan
West Palm beach, FL
njaykaplan
