Stetsom 1k5h $300 plus shipping
logan_searching
Up for sale is my used Stetsom 1k5h used but in excellent condition and never abused
MODELS:
1K5 H – 1 Ohms
Channels:
RMS Power @ 13.8V Mono 1 Ohm:
1830 Watts
RMS Power @ 13.8V Mono 2 Ohms:
1090 Watts
RMS Power @ 13.8V Mono 4 Ohms:
600 Watts
RMS Power @ 12.6V Mono 1 Ohm:
1500 Watts
RMS Power @ 12.6V Mono 2 Ohms:
930 Watts
RMS Power @ 12.6V Mono 4 Ohms:
490 Watts
Minimum Work Impedance:
1 Ohm
Minimum Input Sensitivity:
0,2V
Total Harmonic Distortion:
Signal to Noise:
> 90 dB
Crossover Frequency LOW PASS:
50 a 10 KHz
Freq. Response (-3dB) @ 8 Ohms:
20 Hz a 10 KHz:
Power Tension:
9 a 15V
Consumption with Signal Musical:
72 A
Consumption with Signal BASS:
144 A
Dimensions - mm (H x W x L):
70 x 280 x 170
Weight:
2,2 Kg.
$260 plus shipping
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). [/i
Make me offers
Im sure many on this and other forums can speak out for this amp. I personally have never seen any other amp of this size put out the power this amp can. I had it pushing two xcon 12's which are 1750 watts rms EACH and this thing really moved the pair
How high was the gain tho....??
logan_searching
logan_searching
Franklinton La
logan_searching
