static speakers after 2 amp install
Matt 9
i'm having problems with my new install. one amp is a mono block for the sub. (working fine) my other amp is a 2 channel amp powering the fronts until i can afford a 4 channel to do all of them. my sub works. my fronts are full of static and if i try to close the trunk, a loud buzzing noise goes thru the speakers. should i re ground the amp for the fronts ? or should i try to swap the rca's out for a better pair ? i ran new wires from the doors all the way back. so i'm confident that my speaker wires are fine. any help would be great thanks.
bump, still need help. i will elaborate more. i tried different ground techniques and no luck. front speakers are still real distorted at low volume. i'm wondering if i need to disconnect the factory speaker wires at the head unit since they are not connected to anything except the head unit. i dont understand why my sub works with the monoblock, and the fronts will not work with my 2 channel. i tried swapping rca's from the sub amp to the 2 channel and the same distortion happens. maybe the amp is toast ?
fixed my problem, my 2 channel MA Audio was the issue all along. swapped it out with some crappy old jensen and my front speakers now work again with no noise. i guess after running my old amp bridged for 4 or 5 years, it finally decided not to work in 2 channel mode. time for another upgrade. lol
Matt 9
Matt 9
West Springfield, MA
Matt 9
