dkc62
SoundStream®
I'm going to be building my very first sub floor cabinet myself. I had one before but never did the work so it's my turn to get more familiar at building. I'm going to build it in my '95 Monte Carlo and the subwoofer will be a single Soundstream SPL160. So, I have two different box sizes but I do not know which route to choose and also finding ports that are 4" x either 22" or 16" long. You'll see what I mean.
So here's the first box size.
Ported SPL160
3.0cf @ 27hz, Two 4"x22" ports. High output with low frequency extension. Good small enclosure.
Ported SPL160
4.0 @ 32hz, Three 4"x16" ports. High output with excellent low frequency extension. Great for rock music.
Those are the two box sizes Soundstream. Well lets get to know my Soundstream SPL160 a lot better so you can get an understanding.
Frequency Response Hz 25-500
Sensitivity 96dB
Impedance 2 ohms
RMS (rated watts) 800
FS (Hz) 28
Qts .33
QMS 7.82
Qes .35
Vas (cf3) 7.24
Vas liters 205
Vas m3 .205
CmS (um/N) 183
DCR (ohms) 2.01
Levc (mH) @ 1 KHZ .67
BL (Tesla m) 13.3
Sd (in2) 131.0
Sd (m2) .0845
Sd (cm2) 845
x max; one way (linear mm) 10.0
x mzx; one way (peak mm) 22
Vd (linear cm3) 845
Vd (peak Cm3) 1859
magnet assembly (oz) 345
magnet weight (oz) 157
Vf 385
Coil length (mm) 28.6
Boy, I hope I did a good job with all the information I jotted down. My sub will arrive in the mail by next Thursday or Friday and I would like to get started on building the sub floor cabinet by next weekend. I appreciate all your expertise.
Ported SPL160
Ported SPL160
Sensitivity 96dB
Impedance 2 ohms
FS (Hz) 28
Qts .33
QMS 7.82
Qes .35
Vas (cf3) 7.24
Vas liters 205
Vas m3 .205
CmS (um/N) 183
DCR (ohms) 2.01
BL (Tesla m) 13.3
Sd (in2) 131.0
Sd (m2) .0845
Sd (cm2) 845
Vd (linear cm3) 845
Vd (peak Cm3) 1859
Vf 385
