SSA XCON 10" Finally Available! In Store Now!
soundsolutions
Pro Seller
SoundSolutionsAudio.com
Sub Woofers - SoundSolutionsAudio - XCON - SSA STORE
10" XCON D1/D2 Specifications
Re: 3.7
Fs: 33.2 HZ
Qms: 4.87
Qes: .37
Qts: .35
Mms: 202.5 g
Vas: 15.27 l
Sd: 310 cm^2
Bl: 20.65
Spl: 83.7 1W/1m
Xmax: 29mm
Wattage: 1750wRMS
Displacement: 0.15 cuft
10" Enclosure Recommendations
Sealed: .75-1.00ft^3
Sealed Optimal: 1.0-1.25ft^3
Ported: 1.25-1.50ft^3 @ 27-34hz
Ported Optimal: 1.5-1.75ft^3 @ 27-34hz
Outside Diameter: 11.000"
Inside Diameter: 9.250"
Mounting Depth: 6.000"
Aww, it's so cute lol. Just curious why did you guys just extend the bottom plate (??) rather than add in extra slugs?
It's a larger single slug design, with greater steel in the motor, inferring a stronger motor //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Is the aluminum (I think that's what it is) stronger than the ferrite material used for the slugs themselves (magnetically speaking)?
Beautiful Sub! If this ones ready for purchase, it means the new 10" Icon's can't be far behind! YAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Icon's will be getting some photo's taken here shortly. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You guys just made it a lot easier for me to WANT 4 Xcons in my civic hatch, 4 10's will actually fit without taking my rear seats out yay //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif omg.. I can see the future.. *goes to start saving!*
How would this perform in 4th order compared to '04 XXX?
Good question as we have not put one in a 4th order. We have very few people ask about BP that we don't spend much time on those designs. If someone has the time to model it up, that would be great. Both drivers you are talking about are high xmax, low end monsters, but use different motor topology to get there.
soundsolutions
Pro Seller
soundsolutions
Potsdam, NY
denim
