SSA Icons???
when you say frequency range what are you trying to pick up?
heres the specs if they will help you
# 3” wide, 4 layer, copper voice coil
# Push terminals
# Pulp Fiber Cone
# Dual stiff progressive spiders
# FEA optimized motor structure
# 3" Anodized aluminum former
# Heavy Duty Lead wires
# Design and hand crafted in USA
# Fs 29.9
# Qms 5.87
# Qes .45
# Qts .42
# Mms 212 g
# Sd 480 cm^2
# Vas 43.7 l
# Bl 16.4
# Spl 86.0 1W/1m
# Xmax 20.5mm
# Wattage: 1000wRMS
# Displacement: 0.16cuft
# Push terminals
# Pulp Fiber Cone
# Fs 29.9
# Qms 5.87
# Qes .45
# Qts .42
# Mms 212 g
# Sd 480 cm^2
# Vas 43.7 l
# Bl 16.4
# Spl 86.0 1W/1m
# Xmax 20.5mm
# Wattage: 1000wRMS
yeah im talking about hz. like 15-150hz
don't worry about that, it'll be able to play every frequency that a sub can play. Even if it is able to play to 150hz, there is no reason to play it that high. That is midbass duty.
no i was actually wondering how low it hits. cause the subs i have right now dont hit low notes for sh^t
its a subwoofer......you know what frequencies it plays. why would you want to know any ways? plan on using it as a replacement for a pa or something that has a 12 full range?
helotr3vor
helotr3vor
Irvine, CA
helotaxi
