Ssa dcon12
AnthonyO
Budget Banger Connoisseur
SSA DCON12 single 4ohm
Appearance 9/10
Function 10/10
$115 shipped plus paypal fees
on me
Is this the standard or shallow mount version? Thanks.
Standard
SPECIFICATIONS:
2" wide, 4 layer, copper coil
Push terminals
Pulp Fiber Cone
Dual spiders
FEA optimized motor
2" Anodized alum. former
Heavy Duty Lead wires
Hand crafted in USA
Fs 28.1hz
Re 7.8
Qms 4.98
Qes .34
Qts .32
Mms 136g
Xmax 17mm
Vas 78.1 L
Sd 480 cm^2
BL 23.1
SPL 89.2 1W/1m
Wattage: 400wRMS
Displacement: 0.13ft^3
Enclosure Recommendations:
Sealed: .75 - 1.0 cu.ft.
Ported: 1.75 - 2.25 cu.ft. @ 28-33 hz
Sub Outside Dia.: 12.500”
Cut Inside Dia.: 11.150”
Mounting depth: 6.00"
Displacement: 0.13 ft^3
That is what GOD invented Dremel and sanding/cutting disc for. ;)
217
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
969
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
AnthonyO
AnthonyO
Minot, North Dakota, United States
AnthonyO
Brendon Jenness
    May 8, 2024
    May 8, 2024
