SS XXX-4000D Power Needs
SacTownBully84
i just bought a SS XXX-4000D and i got all monster 400 1/0 on big 3 and 1 run through car to trunk and i have a stinger SPV70 in back and stock battery front i also ordered a 200 amp HO ALT i was wonderin if this will be enough or should i replace the stock battery up front with a optima YT D75/25 or what rout to go thanks in advance
depending on how much current the amp draws, you should have a bigger alt, a new batt up front, and at least 2 for a batt bank. add if you're still dropping voltage. What ohm load are you running? if youre going to be @ 1 or below, you most likely need a little more juice.
k imma get another SPV70 and a Optima YT D75/25 and i should b good stinger rates the SPV70 @ 2100watt systems so 2 should b cool thanks 4 the help bro
PS the amp is rated @ 280Amp current draw also if that help ne one
SacTownBully84
SacTownBully84
New London IA
SacTownBully84
vegang
vegang
