sq.in. of port per cu.ft. of box
k_schutte
OK I think the general rule is like 14-16 sq.in. of port per cu.ft. of box but that is for slot port. Does it change at all when going to aero ports? I ask because I know aeros are more "efficient" than slots but I am not sure how far that goes and what not...
My box is going to be 7ft^3 net and I can do three 6" aeros which will give me roughly 85"^2 of port (about 12sq.in. per cubic foot) or I can add a fourth and get 113"^2 of port (about 16sq.in. per cubic foot).
Well, some people go by the rule of 8-12 sq. in. per cubic foot but it really depends on the power that you will be running to it. for example you could use a 3" port for subx and run 500rms to it and have no port noise at all, if you run 1500 to subx and have a 3" port you could have port noise. Yes, aero ports are more efficient and when I calculate how much port area I generally use no less than 5 square inches of port per cube and have never had problems.
it will be getting 2K~ daily and 5K~ for burps. I just wasn't sure if I should go with 3 or 4 ports but after reading around it sounds like 12"^2 of port per ft^3 of box seems just fine.
my port area is bigger then my subs. what r u going for?
edit: just read above post. go for one and stick to it. burps require larger port while bassracing requires more of controlling the sub
k_schutte
k_schutte
cedar rapids, IA
bassman3
