disturbed471985
I am changing my setup and going for a somewhat sq setup. Not a sq setup per say but more sq then spl. I will be running no subs of any kind. Amp to be used is my MBQ 4.125 does 250x4@2ohm rms. Whats ur thoughts?? Mids will be crossed from 65hz - 5k and the tweets will be crossed at 1.8k and up...
First run 4 of these - Silver Flute W17RC38-04 ohm 6-1/2" Wool Cone: Madisound Speaker Store wire each pair for a 2ohm load and run one set off channel 1 and second set off channel 2. So each set would see 250 watts all 4 getting 500. 2 in the doors and the other 2 in the deck.
Then use channels 3&4 I will run 2 sets of SB Acoustics SB26STCN-C000-4 tweeter, 4 ohms: Madisound Speaker Store each paired wired down to a 2ohm load per channel. So each set would see 250 watts all 4 getting 500. All 4 will be on the a pillars.
Real help needed. No bs if u dnt know what u speak then plz leave. Not looking for perfect sq just something loud and clean and clear.
