Sold SPY's Updated FS thread - New stuff added and price changes
SPY
1. Product:
Eclipse CD8053
Eclipse 37601 Balanced Line Adaptor
2. Specs:
Eclipse car audio CD8053 key features
Balanced outputs
High voltage 16V/8V and low impedance outputs
All digital circuitry
STAR DSP (newly designed Digital Signal Processor)
24-bit advanced multi-bit Digital-to-Analog Converter
CD-R/CD-RW compatibility
MP3 playback using optional ECLIPSE Commander Advance
Full dot VF display
Power tilting front panel
Digital input
Auxiliary input
Eclipse car audio CD8053 power output
High voltage 16V/8V Balanced Line Pre-Amp Only
Eclipse car audio CD8053 CD features
CD-R/RW Compatible
ECLIPSE Memory Buffer
CD Text
CD Name Preset
Track Scan
Track Up/Down
Fast Up/Down
Repeat
Random Play
Eclipse car audio CD8053 tuner features
PLL Frequency Synthesized Electric Tuner
ECLIPSE STARTUNER V
24 Station Presets (18FM/6AM)
Preset Scan
Auto Station Memory (ASM)
UP/Down Auto Seek
One-Touch Station Memory
Auto Local/Distant Seek Sensitivity
Eclipse car audio CD8053 audio features
Independent Bass/Mid/Treble Memory for each Source
Balance Control
Fader & Pre-Amp Fader Control
Loudness
Mute
3 Pairs of RCA Pre-Amp Outputs
Specs for the BLA (37601):
Supply Voltage: 13.8V DC (10.8 ~ 15.6V)
Current Consumption Approx: 0.25A max
Frequency Response: 20 ~30.000Hz, ±2dB
Distortion: 0.005% (1Hz, 1V)
S/N Ratio: 106dB (IHF-A network)
Input Impedance: 12kΩ
Output Impedance: 220Ω
Max. Output Voltage: 10V (1kHz)
Common Mode Rejection: 60dB (1kHz)
Dimensions (W × H × D): 6.14˝ × 1.50˝ × 1.97˝ (156 × 38 × 50mm)
Weight: 0.72lbs (0.33kg)
3. Description/Condition:
Used but in good cosmetic and mechanical condition.
Includes HU, cage, trim ring, wire harness, knob remote, credit card remote, and balanced line adaptor.
4. Price: :
$250 + shipping
5. Pictures:
1. Product:
Alpine PXA-H701 + Alpine RUX-C701
2. Specs:
http://vault.alpine-usa.com/products/documents/OM%20PXA-H701.pdf
Used but in good working condition.
Includes H701 unit, power harness and Ai net cable, C701 remote unit, connecting cable and mounting cage. Mounting cage has been trimmed but should still work just fine or you can get a new one for about $15 at Appliance parts, electronics parts more from PartStore.com
4. Price: :
$550 shipped
5. Pictures:
1. Product:
I call it the RL-e8
2. Specs:
Sound Splinter RL-i motor and basket with Sundown e8 soft parts. e8 soft parts are SVC 4ohm and rated for 200w but we all know they will take more.
It has seen power only to test the recone.
4. Price: :
$100 + shipping
5. Pictures:
1. Product:
PPI PRO flat piston 12" sub
2. Specs:
SVC 4ohm
Mint
4. Price: :
$125 + shipping
5. Pictures:
1. Product:
12" Si Mag V4
2. Specs:
At first glance it is more compact than the average subwoofer. As a matter of fact, it is more compact than the average subwoofer. At only 5.5” total depth, it allows you to mount the new Mag v4 in an enclosure that is only 4.75” deep.** With its XBL^2 enabled motor it supplies you with only the most true, clean, deep, aural experience possible. Its soft parts have even been over-designed; using only the best technology such as a Kevlar composite paper pulp cone along with woven-on tinsel leads and a linear 8” diameter spider that allows for the utmost distortion-free operation possible. The all-new Mag v4. Great engineering is great engineering at any size.
D2ohm
BNIB
4. Price: :
$225 + shipping
5. Pictures:
1. Product:
15" Oz Audio Power series
2. Specs:
QVC 1ohm, 4000 rms/ 8000 max
PM me your email addy and I will send the manual in PDF
good condition
4. Price: :
$250 + shipping
5. Pictures:
1. Product:
New style 15" RE Audio XXX
2. Specs:
Technical Specifications - RE AUDIO
Good condition, DVC 2ohm, comes in original shipping crate
4. Price: :
$500 + shipping
5. Pictures:
1. Product:
15" LMS Ultra
2. Specs:
Audiopulse
Has blue AP basket and black TC Sounds cone, DVC 2ohm.
It does have some minor cosmetic flaws from damage due to shipping from the previous owner but it should not affect performance at all. There are some ripples in the center of the cone and a ding along the outer edge. I did my best to capture these flaws in the pics, they actually look worse in the pics than in person.
4. Price: :
$650 + shipping
5. Pictures:
1. Product:
Memphis MCH1300
also know as the Memphis Big Belle
2. Specs:
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custom Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms
115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!)
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 25.81" L x 7.6" W x 2.4" H
Used but in good working condition. Has some minor marks on the top as shown in pic #2 and also has a small piece of plastic broken off the front right corner as shown in pics #1 and #3, I do have this piece so you can glue it back on if you wish.
4. Price: :
$400 + shipping
5. Pictures:
1. Product:
Box: 4.0ft^3 tuned 30hz for a single 15” sub
2. Specs:
Box is 45.5”w x 14”h x 17”d, 4.0ft^3 tuned to 30hz with a single 6” aeroport. Box includes 3 interchangeable baffles, 14.5, 14.25, 14.125 cutouts, installed using T-nuts. Aero was used in a previous box and had to be cut to get it out but it still works fine. Box is bare wood right now but I can carpet it in your choice of black, charcoal or light gray for an additional cost. Does not have a speaker terminal but I can add a basic one for free or a threaded rod and bolts setup at additional cost.
New
4. Price: :
$75 + shipping as-is
Add $25 for carpet
Add $5 for threaded rod and bolts speaker terminal
5. Pictures:
Picture doesn’t show the 2nd baffle or removable baffles.
1. Product:
Box 4.0ft^3 tuned to 30hz for a single 15” sub
2. Specs:
Box is 40”w x 14”h x 19.25”d, 4.0ft^3 tuned to 30hz with a single 6” aeroport. Box includes 3 interchangeable baffles, 14.5, 14.25, 14.125 cutouts, installed using T-nuts. Box is covered in charcoal carpet and had a light gray 2 tone carpeted logo on top. Has threaded rod and bolts for speaker terminals.
Used but looks new
4. Price: :
$200 + shipping
5. Pictures:
1. Product:
Box 2.27ft^3 tuned to 40hz for 3 8” subs
2. Specs:
Box is 34”w x 16”d x 14.5”h, 2.27 ft^3 net vol tuned to 40hz, designed for 3 DD 1508’s but will work for a lot of subs. Double front baffle with oval recessed cutout for the subs, kerfed port, white painted port and sub mounting area with black carpet. Screw type speaker terminal.
Used but in good condition
4. Price: :
$125 + shipping
5. Pictures:
1. Product:
Prefab box for 10” sub
2. Specs:
aprox 1ft^3 sealed box, gray carpet, speaker terminal, slanted front.
Had a sub mounted in it but never played.
4. Price: :
$10 + shipping
5. Pictures:
1. Product:
Red LED tube
2. Specs:
They are red
used but I was told they work fine
4. Price: :
$20 + shipping
5. Pictures:
1. Product:
Orion sign
2. Specs:
Metal with Orion logo cut out of it
Excellent condition 20”w x 13.75”h x 1/16th” thick
4. Price: :
$35 + shipping
5. Pictures:
1. Product:
Sound Stream Grill
2. Specs:
15”
I was told it was new when I bought it, not sure that is true but it is in very good condition.
4. Price: :
$40 + shipping
5. Pictures:
ugh, wish i had cash for that 8053. Is the manual included?
No manual, sorry.
My old Oz 15 want it back but no $s right now. Good luck SPY. Oh did you get the paypal I sent earlier?
The OZ is a killer sub, sounded good and got loud on my SAZ-3000D, I'm using it right now on my Memphis Big Belle, not quite as loud but more musical with less power.
and yes I gt the PP, I have the design done, I'll PM you on CACO to make sure it's what you want before doing the cutsheet.
SPY
SPY
NY
SPY
vegang
vegang
