spray on bedliner
i get the dupli color stuff from oriely. i used 1 can on all 4 15 inch wheels and got1 solid and 1 iffy coat on my box. the box was for an 8 so it was a bit small. i recomend getting some 99c black paint to spray underneath and then sand quick just so you dont use as much of the expensive bedliner.
Don't skimp with the walmart spray shit. Go to a real shop that has a bedlining setup. Its a hot coat epoxy process thats at 150 degrees but by time it gets on the surface of the box its cold and there permenantly. I did my entire wall inside and out with the stuff and it will hold water now. Well worth the cost.
Here is a fart box I did in 2007
pic doesnt work
---------- Post added at 01:17 PM ---------- Previous post was at 01:16 PM ----------
im gonna pic up a can at piston ring and see how it works its cheap enough to give it a try anyways
hey snoop how much did it cost you to have it done, the stuff i bought is alright but it isnt very gritty.
paid a bedliner shop $50 ....Well worth it, I had that box for about 5 years and not one scratch on it. I threw it around all the time just to see if it would crack/peal and nope, not one bit!
splwj47
splwj47
Great White North
goingdef
