Splitting RCA cables?
That would work. This will half the voltage coming from each set, though. Not necessarily a bad thing, but the chance of noise in your system is greater. Luckily for you, just about every head unit made in the past decade comes with at least two sets of RCA outputs.
Well, im goign to add another amp and subwoofer to my car soon and the alpine pdx 4.100 takes up both of the rca outputs. How would i run the rca cable to the new amp and sub?
Is there another way to do this w/out causing voltage drop?
you could get an Audiocontrol 6XS that would take 2 pairs in and 3 pairs out. it would put your voltage ~8volts.
I dont have that kind money right now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. I wish could afford that. Any other ideas?
That's not how it works.
Y cables create a parallel connection.
Fundamentals of parallel circuits say voltage is equal at all points, it's the current that changes. Since line level signals operate at such small current it is no problem for the HU to double current output several times before it starts to stress.
So no, you don't lose voltage with y cables.
you don't have to get an Audiocontrol unit, there are many other brand units that you could get.
i've used this before and it did pretty good.
http://cgi.ebay.com/POWER-ACOUSTIK-C3184-3-Way-Electronic-Crossover_W0QQitemZ220387199441QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item220387199441&_trksid=p3286.m20.l1116
That's not how it works.Y cables create a parallel connection.
this
My bad - you guys are correct. I wonder, then, why I always have to turn the gains up when using a splitter to achieve the same volume level I had before splitting the signal? Perhaps the drop in efficiency makes the audible difference.
Most amps also have an RCA out - I would use that before I would split RCA's.
you dont even have to do all that.
you could simply run both sets from HU into 1st amp, then from amp output into 2nd amp input.
Hello! My name is misinformation, and I happen to be completely wrong!
The output voltage is the exact same if you split it or not. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Imagine that! A parallel circuit not losing voltage. Geez. Physics is amazing! :facepalm:
ttt0649
ttt0649
Wichita Falls,TX
IDSkoT
Mike Mccabe
