tommyk90
THE WHOLE THING!!!
Well kiddies, lately I was being pwnt by the SPL gods.
I was doing testing with my single 15" box that I posted on this forum a loooong time ago. Now back then (around MECA finals time last year), and up until about a month ago, it would do a around a 154 in the kick.
Well, I was testing some stuff recently to get this thing dialed in for MECA finals this year. I didn't change ANYTHING from all the previous testing, but yet somehow I lost over 2 dB! It would barely break a 152!
Needless to say I was pretty pissed, and tried a LOT of things to figure out what was wrong. This included
1) Swapping amps
2) Swapping headunits
3) Swapping subs
4) Different ports
All of these things did absolutely squat, and I couldn't figure out why. During one of the burps I decided to stick my head in and gave a listen. To my amazement, the sub was backing the screws out of the box! So I drilled new, tight, holes and mounted the sub again. This time, instead of the screws backing out, it just broke the heads off!
Well, at least I knew ONE of the problems. So to solve that issue I decided to use bolts instead of screws. This idea solved that issue and kept the sub sealed against the baffle. So that should be it right?
WRONG. Still down 2.5 dB!
So, after some talking with a few people, I decided that maybe my baffle isn't strong enough, even though I NEVER, EVER had problems before.
So, much to my dismay, I decided to brace the baffle using some threaded rod since I couldn't add another layer (box would be too deep). Now I've never been a fan of internal bracing because of added turbulence and whatnot, but right after I did the next burp I KNEW that I had made a change for the better.
After adding the threaded rod, I gained back 2.5 dB!
So the moral of the story is, MAKE SURE YOUR BAFFLE IS STRONG!! No matter what it takes. If it was me, I would start with a double/triple baffle if at all possible. If that's not possible, then 5/8" or larger threaded rod is a must. IMO, do NOT use wood for internal bracing. It's just not solid enough especially when it's thin.
*cliffsnotes* Lost 2 dB out of the blue, baffle was apparently weakened. Braced baffle, gained back 2+ dB. Make sure your shit is strong
1) Swapping amps
3) Swapping subs
4) Different ports
