pioneerpimp
i need some information, tips, instructions, etc. due to cancellation issues, i am rebuilding a box for my MTs, as well as getting a much larger amplification unit. i have a few question:
along with double baffling, with kind of other supports work best. i have heard tie rod threading is a good choice. i had triple baffle on my last box, but i think it was a little unnecessary and added alot of weight.
I also have a 1990 dodge grand caravan. what is the best way to fire into these. sub up port back? sub back port back? sub up, port up? sub and port towards front of vehicle? sub back, port firing towards front? who has had some good numbers in any of these positions.
also, how much does fiberglass resign help, and if im going to do it, should i do whole box or jus corners?
45 degree corners, help at all or not?
wud a port per woofer, in almost separate chambers be better than one big box with one port, for less cancellation, it it becomes a problem?
I am looking to tune at 30 hertz.
Also, I am running MTs, who has had the best numbers at lower 30's freqs, and it what amount of cubic feet boxes were these MTs in. ive seen so many different sizes, looking to do research for volume now.
Also, slot port to Aero ports, differences in both, and which one is better for higher numbers?
also, rounded port corners everyone always suggests. I have been doing this on my last 7 boxes, but never really understood why except for better air flow, any other reasons?
which is the best tightening solution when it comes to wood glue, i use liquid nails but am looking for something different, that may hold better.
also, i see SPL competitors dont use rubber gaskets around their subs, and some even go to the length of duct tape, im guessing to hold in air, anymore explanations. why dont some people use rubber gaskets?
Next, which way is the best way to lay out subs in a box, although this may go hand in hand in positioning of subs.
i was told by a knowledgeable competitor, to do a box, with a port across the bottom of the whole box, so no cancellation occurs as long as subs are side by side. im thinking bout this heavily, any other way to do it? is there any other way to manipulate air movement.
these are just a couple of things I would like to discuss with some people, get a little bit of help on some things, please do not call me a noob or make fun of me or thread dump if you do not like all my questions, then u dont have to answer them. please save all smart *** responses to yourself also. would just like this to be an informative discussion to help me and other people when theyre building boxes.
Thanks and I appreciate all the help I can get if any. I know its a lot of questions.
anymore questions i can think of I will post. thanks again
